George,Quote:
Originally posted by GeorgeK
Bryan,
My car has the same plastic framed horn pad, and mine was also cracked on the left! I glued it using epoxy (Araldit), seems to hold OK.
If you need an alloy frame for the horn pad, I have one, with the Wolfsburg VW pad on. It's yours for the price of mail.
GeorgeK
That is really interesting yours is broken in the same place. Guess everyone uses their left thumb to honk the horn. Thanks for the offer for a metal replacement. I will try to repair mine first just to keep the original on there. I will replace the rubber spring also. Would you guys recommend glueing the rubber center piece back on the plastic 'butterfly' or just leave it as is? Thanks.
