Doug, I think Gordon gave you a good summary. Was not aware of the issue with the oil tank level but this is probably the one you least need. If you want to use the spot, have it converted into a voltage gauge.
Then again, if you are planning on converting it into a hot rod, you should discuss options with the builder. They may have good ideas.
