Originally Posted by
classic
A note book for parts.....as you disassemble the component you can make a note of anything that needs replacing, and instructions on finish required. Makes it easier to search through the parts manuals for numbers in fron of the TV.
Nothing worse then getting a batch of stuff back from the powder coater, and finding you left one piece behind.
You'll end up with a number of sub assemblies, that can be taken down further, depending how far down the slope you are traveling.
+ 1 on the boxes.......I used clear, with a note on the inside, of what it contained, and if it needed refinishing ect. You'll end up with a lot of boxes.
If you're pulling the wiring loom/gauges take a 100 photos and notes, and then take some more, and back them up on a stick (just ask me how I know)
A good stereo for the garage/work space!
