9 Attachment(s)
Stripping a Painted Floor
(Your deity here) --- was not looking forward t' this part
Wasn't exactly sure quite what kinda finish had been used here. But --- whatever the paint/stain/coating was? . . . hot tires had already been removing it for years before I got there --- prolly from the beginning. Fast-forward eight-some years and this stuff now was coming-off on my hands. Fugly color, too. Concrete's already gray so? . . . why bother painting it gray? Weird
Anyway, had several options for removal . . .
..1) chemical stripper --- ugh! . . . deadly-poison, noxious fumes, waste disposal = pass
..2) pressure washer --- this looked attractive, but . . . I'd prolly end up with my garage if not soaking wet, than, at least, soggy. A lot of exposed lumbar + sheet-rock in my garage + never used one before = lemmethinkaboutit
..3) mechanical stripper --- like the one in my trunk . . . see previous post
Actually bought a can of paint stripper --- to test it out . . . like, <$10 for a ~quart-size can. 'Apply + wait 15 minutes' = meh!
Pressure washer seemed kinda problematic, so . . .
. . . tah-daaaah! . . .
. . . grinder it is
Home Depot was down the street --- and they had everything I needed + then some, so . . . $123/day got me a machine + grinder. Requisite eye/lung protection was another $46. I already had ear-protection, so . . .
. . . off to the races
Thing is heavy as hell, too --- maybe 50 lbs? . . . + not small --- but fit in my car trunk (more-or-less). Took a little getting used-to to use. Ended-up maneuvering the grinder by tilting/putting pressure on the corner of the pad --- pretty easy once I got the hang of it. Started-out working in small areas, trying to get every last molecule of paint off --- and taking WAY to much time, in the process . . . then settled on a simple 'sweep' technique --- swinging the grinder in 6-foot arcs . . . making better/faster progress
Not exactly strenuous, but --- in >100-degree heat? . . . made for a long day
'Keep the stomach tight + watch the back'
