$8 - $10000............... way to high.
Remember that the pan has your a arm pick up points in it. If it is not jigged properly with a suspension jig, and welded into place by a novice, you may have a very hard time mounting your suspension, or trueing up the car. Its critical that the pan be located correctly.
