So this is their answer
Hello Uli,
Sorry this took so long but it took a while for me to replicate the problem on the test rig. When I introduce some air into the system, I can make the valve respond similarly to what you have seen in your car. I think the problem is with the volume of fluid trying to flow through the valve. I also noticed in your video that the brake pedal is taking a very large amount of travel to actuate (indicating either air in the system or the drum brake shoes being out of adjustment). So it seems like in this condition, with a large increase in fluid displacement through the valve, that it is able to get stuck in position.
I would be interested to see what happens in your car when the shoes are properly adjusted and the system is bled thoroughly.
Regards,
and my reply
Hello Jason,
when I remove the pressure gauge I have a firm pedal, but the problem persists.
I have a bleeding thing that puts pressure on the fluid container and has vacuum at the bleeder valves. I’ve even bled the system with the rear jacked up to make sure the valve in the tunnel isn’t the highest spot. I’ve tried both with the shoes adjusted for minimal clearance and with reset adjusters, but it makes no difference.
Out of curiosity I tried blowing through the valve from the “out” connection. Wasn’t possible with a bit of preload on the adjuster.
Any more ideas?
Thanks Uli
