10 Attachment(s)
Museum car (020) and 1973 Le Mans et
I am warming to the idea that the Museum car is R2 (020) AND was the #48 Sonauto car at Le Mans as claimed by the museum and reported by Milou.
Assuming it was also the #9 Targa car for a minute, and it was taken back to the factory and repaired, including 2 new rear quarter panels, the following can be argued:
The first photo of the 48 cars shows what looks to be silver trim around the RHS rear light cluster. This is consistent with the targa photos. More importantly you can see the Le Mans lights for the racing numbers mid way down the rear of the door.
After the race it appears to be used as a test mule for VERY wide wheels - next pic. In this experiment all of the rear quarter panels are cut away but the rest of the car is intact.
Then If you assume it is rebuilt as a museum / promo car (by this time the 1973 season is about over) it is THEN used for magazine articles, including the Paul Frere drive and article.
The next picture shows a close up of him with the car. Note the hole in the door panel at about the correct spot for a Le Mans light. It is present in the other photos but I had not noticed it before thinking it was a mark on the photo. This one is very clear though with the screw holes also visible.
Obviously with all the rear quarter panels being off for the testing, and then the car being "restored", it would have easy to not only replace the quarter panels but also redo the oil tank set up. Indeed that may have been done before Le Mans if there was a fair bit of damage to repair - as the reports seem to indicate.
So the outer panels are not likely to give an indication of the oil tank system by that time.
We know from the museum photos earlier on this thread that some signs of a 72 oil system still exist on the inner panels and door frame. So there is nothing here inconsistent with the Museum car being also the 48 car at Le Mans (in fact it is likely) and that is still consistent with the car originally being based on a 1972 shell.
From the posts above it is also the #62 car at the Le Mans test weekend, and although the picture is not conclusive there does not appear to be an oil door in that picture either. Also in that picture the rear quarter panel looks "normal" for a 73 car and not like the 72 Strahle car.
Finally it is also supposed to be the #2 LEO-ZA-69 Targa Corse car. I can't see an oil door in any of the pictures of that car either.
What if the Targa Florio photo is the odd one out - the car may be R2 BUT what if the accident with the tree that Pucci is supposed to have had with the car necessitated the replacement of the whole RHS rear quarter panel AND / OR the rough grafting on of wider flares? The rough work on the whole of the rear guard is clearly visible in the photo.
It may even be a replacement quarter panel. I think it is important to clearly look at the photos / video of car #9 in practice before the accident as the only ones here are after the accident and repair.
Whether or not John Starkey's speculation that it is ALSO car 002 remains unclear.
