For $119k asking…
For $119k asking…
Last seen it was Silver Metallic . . .
June 2016 - Sold on BaT for US$36,000 (+BaT fees)
Looks good in Blue.
Sold for: US$160,999 (+BaT fees on 4/1/22)
Attachment 571888
Okey dokey as a long time trawler of this thread and noticing that the "what happened next" part of the story of the cars that are up for sale rarely gets reported on - so here's closing the loop on this one - I may be posting in the wrong spot in which case sorry about that.
Fair warning - I tend to ramble. Second up - this is absolutely not a moan at any previous owner - once upon a time these cars didn't command the prices they do now, so I can understand why folks wouldn't tip a sht ton of cash into them and you make your choices and trade offs based on the circumstances at the time.
That said the time has come to unpack, unpick and resolve those trade offs ..... the below started at the beginning of February - yes it's turned into a restoration - yes there's a tight deadline (Classic Le Mans 30th of June) - no I'm not doing the work myself - it's way beyond my skillset in this timeframe - does getting into this at this expense worth it, probably not but then meh.... I wanted an early 73 coupe with MFI ideally in Gulf Orange
So I bought this back in May with the intent of it being an occasional driver with some interior pottering and in the thinking that at this price there would be "something" lurking and had it shipped over to the UK. It arrived at the end of September a little worse for wear after getting roughed up in the shipping container.
That then accelerated the intent and need of taking a good look under the damage and dings to it....
Much to commend the car on the quality of the floor pans, engine, headlining, carpet and the roof is super sound. That's where the list ends.
Things that were found to be funky
At the front:
At some point someone (I'm guessing when it was repainted red moons ago) has stuck the front into a lamp post. Not enough to interfere with the inner wing crumple zones but enough for the S bumper to full of filler, the panel behind it, the suspension pan to be properly mullered - though some truly epic bodge repairs have been done. Same for the driver's side (US) wing to be fibreglass as was one of the fender joining plates which looked to be a home made thing - the other being possibly original but well done.
The tank support and battery boxes along with the inner wings around them generally best described as deformed rust (?) and quite possibly because of the above lamppost the bonnet wasn't quite right and nor were the bonnet hinges, some extreme adjustments to the front passenger side camber were observed to account for the bent wishbone beneath. Up above a nominal amount of rust in the windscreen corners
Resolution: New front wings, and fender joining plates, suspension pan, tank support, front inner wings, battery boxes, front panels, S bumper, wishbones, bonnet hinges have been bought. A day of panel beating to the bonnet and repairs around the windscreen. The remains of the aircon in the smugglers is in the bin as is the mouse house that was in there.
Going back - bottom of the driver's door pretty poorly repaired some time back and the other being OK but again well holed along the bottom. Bottoms of the A posts rotten, inner and outer sills rotten. Kidney bowls rotten though some signs of previous repairs (exceptionally) poorly done. B posts had been replaced at some point, but pretty haphazardly so the doors were permanently not quite right.
Resolution: Lead in one door and whole new skin in the other. Replacement of the bottom of the A posts and new inner / outer sills and kidneys with new metal being let in up and around the doors, new B posts.
Going further back - both rear wings could have been repaired from being roughed up in the container BUT - the clock is ticking for Classic Le Mans! which is a pity as they weren't crp. The rear panel had some signs of an earlier ding, but again roughed up in the container. The engine lid - very roughed up in the container. The rear bumper corners were sound though their supports had some rot in them
Resolution: Two new rear wings, new complete rear panel, another day of panel beating for the engine lid and bumper corners taken back to bare metal and the supports repaired.
Other bits - ball joints, rear wheel bearings, brake pads and shoes, suspension bushes and a bunch of other stuff all past their best and being replaced.
Current state:
All of the above purchased along with S trims, end caps, letters etc in black, seals, gaskets, deadening, carpet, 964 covers and other oil leak stuff and seals, engine and gearbox service stuff etc etc etc
Doors done
Inner sills done
A posts done
Rear wings and B posts, outer sills tacked on, doors refitted to confirm initial measurements and ensure panel gaps
Rear panel in
Engine lid and bonnet beaten back to spec
Parts that are still good are passing through the blaster for repainting
Next up:
Completion of the rear wings, B posts and outer sills
Make sure the blaster is never turned off
Get the work on the front going
Paint - Gulf Orange
Interior - grey perlon, black vinyl, obligatory rep sports seats
See it was a ramble - will it be ready by the end of June and Le Mans, it's going to be tight we shall see
Wow, that is definitely a long list. You seem to have a good attitude about it too, which is great. I think with these cars, there might not be 'bargains' necessairly, considering their age; they all seem to need a list of items to address. They are just such great cars which makes them worth the spend and time... Thanks for sharing!
Back for sale, inquire for price
9113111867
https://www.europeancollectibles.com...che-911t-targa
Strange, the BaT listing does not show up when you google the VIN. Is it just me?
Also no mention of the 2.7L modification. Did prior owner revert the car back to 2.4?:confused:
Chartreuse/Lime Green
January 2018 - Listed by Makellos Classics (original restorer)
July 2019 - Listed on Petrolicious Marketplace (by Makellos)
September 2021 - Listed on Bring-a-Trailer (by Makellos)
Attachment 572782
Attachment 572783
March 2016 - Listed by Road Scholars
December 2021 - Listed by K. Watt
Now on BaT
Sold for: US$157,000 (+BaT fees on 4/14/22)
Attachment 572784
9110100385 back on eBay.
https://www.ebay.com/itm/1970-Porsche-911-/275247429721
