The very first picture shows the front struts. They are painted orange. They are pinch bolted to the front suspension and don't need to be removed. What you get from Koni replaces the inserts that go inside them. Maybe what is confusing is that the new Koni inserts are also painted orange, You remove the gland nut at the top of the strut to pull the innards out (you see them in my pics, but they aren't painted) and suck out the old oil (or just tip the shock over after you have removed the innards). At the back it's just a straight swap of what Koni sends, orange body and all.
Ravi
