where is here? kinda sounds like you'd expect. :) neat little setup!
Hi I live in the uk and the car has to have a Ministry of Transport Test or MoT before I can drive it legally . The weather is really wet and the car hasn't seen rain for at least 12 years .I don't want to have my first experience of driving 200 hp plus in a 1000kg car on 185 tyres in the rain......It might end in tears. Glad it sounds as you might expect.... I don't have much experience to go on.
cheers
andy
you'll be okay. its okay to play around to get the feel of it, otherwise you never will. good luck! :) I definitely had a few whoaaaally shit moments playing around in the SC, but once you get a feel for the jive of the car you know a bit more about what to expect.
((((Arg - Still waiting for my ECU... but i guess it gonna be soon.. i am so dang hopeful...))))
when the car is running.. . projects include, final adjust of clutch cable after the clutch assembly weld, toe-in align after install of turbo tie rods, check injectors, sniff for gas in the engine bay and check both warm and cold fuel idle, check all lights/fuses/grounds that I didn't bump anything off.
Taking Fuchs j15x7 and j15x8 to Harvey tomorrow.. Gotta get them out of A. Bauer Repair this morning sometime... to be massaged and swapped. Harvey.. i hope you can feel a little better.
For the '65, put the new cover on the oil tank sender today...
Attachment 245240
Removed original standard front bumper (tangerine) and fitted factory steel S chin spoiler (sepia brown). Now it's time to learn how to spray paint.
Attachment 245602
I've been hoarding this for years, finally put a NOS leather boot in on the '65.
Attachment 245364
I work my dashboard, wanted to turn the alloy into something else, took the vinyl, glue, bush, sewing machine and Porsche embossed leather piece.
Attachment 245757Attachment 245758Attachment 245759Attachment 245760Attachment 245761
That looks great!
Drove my car with Solexes installed for the first time!
Some words of wisdom to those aspiring to do the same: don't expect it to be easy - these carbs are a world apart from Webers. Solexes are a complicated system and getting them sorted, even after being rebuilt is not for the squeamish. This install took three years and more $$$ than I'd possibly imagined to make happen! Here they are:
http://i25.photobucket.com/albums/c7...400_resize.jpg
