4 Attachment(s)
Does car 48 at Le Mans have an oil door after all?
Earlier in this thread it was established that car 48 at Le Mans in 1973, the Sonauto entered car for Gregg and Chasseuil, was R2.
Looking at the photos it appeared that this version of the car no longer had an oil door.
However, given the pictures of car 61 at Le Mans test, the clear oil door at the Targa, and how difficult it is to see the oil door on the TdC #2 car despite good photos, I think it is necessary to reexamine whether or not there is an oil door on car 48, or if it is a case of the photos not being good enough.
The two photos of the car that I have that show the correct area, posted below, do not show an oil door.
However they are both low resolution photos and the area is indistinct. I cannot even see the gap at the trailing edge of the door. Given how hard it is to see the oil door on the TdC car (the level of clarity is about the same as the trailing edge door gap) I think it is not correct to say there is no oil door (unless it cant be seen and the door gap is clearly visible).
Rather I think we need a much better photo before a call can be made, and on what I have seen in recent photos I would be willing to argue that it is more likely than not that there IS an oil door on car 48 even though I can't see it.
