http://forums.pelicanparts.com/porsc...bers-40mm.html
10912 901/03 2080381
correction to 11608, the correct serial is 4080594
correction to 18538, the correct type is 901/19
Hi Dave,
I found this picture of a 68S I restored and sold a long time ago, it is not in your list yet.
Vin 11850083
Eng 4080306
901/02
10378 (?)
Henk.
Here’s one for you, from an engine I just picked up.
*902313*
901/01
2213
Thanks guys.
Paul can you find the pairing #'s on the top of the case, the casting dates for each half under the pulley, and the casting part #'s under the oil tubes on each half please.
Hello
My dad bought a 1967 911s soft window we are trying to determine if it is a matching numbers car the engine is 901/02 54 and the engine #is 900 054 I dont see the numbers in the sequences that you show on the first page of the thread.
Whats the VIN on the SWT ?
Sorry, I missed this post. I think that if the car is a 1967 911S, then the engine type is 901/02 and the engine # would be 960054; there should also be a build # just below the type # 901/02. I can guess if the engine and VIN might be matching if you provide the VIN, but only a COA would say for certain. A phone call could confirm it.
I have an engine that I've been told is a 1965 911 - I've attached photos that show the number 901901.
Attachment 229394
Attachment 229395Attachment 229396
