Have a alu cast in 65 but can't find much info on it and serial seems odd to me...
901/01 build #2186 odd serial number is 743901
Any info would be appriciated
I'm currently holding the following 2 cases/engines:
907433
907600
Dave, I believe I gave you the rest of the #s via PM.
and for the list:
901/02
960029
5316
Hi
Thank you for the response I think the build #was 64 it was under the 901/02 I will check to see if that is a 6 and not a zero the vin is 500100 and this is new to me who do I contact for a coa thanks for the help
Bret
Picked this up today. 900593, 901/01, build #493, case halves 717.
Casting and date numbers. Also came with matching heads.
Just added 69 2.0 S # 6390463 to the fleet
Another one:
903068
901/01
2968
pairing 607
Richard
