4 Attachment(s)
Oil tank, lines, filler neck and cap
Several board members contributed to the research and analysis of the ST cooling system for engine lubricant, OliverR, Raj and Gib most prominent amongst them. That was back when this thread started over two years ago. Many thanks to all.
The following images provide further detail on the direction we took with the filler neck, dry sump tank and lines.
The steel 80mm Blau oil filler cap may be from one of John Starkey's old cars. It came on an RSR oil tank that was sold onwards to another project when the decisioin was taken to stick with the original MY 1971 oil tank, now enlarged and baffled courtesy of Fabcar. The original MY 1971 oil tank allowed us to retain the original oil thermostat set-up, correct for a 2,3L "ST."
Many period images exist validating Race Department use of the the large Blau oil fill cap on the Safari prepped 2,3L "ST."
Jim Logan provided the wide mouth filler neck about five years ago; I think he made some of these up for sale to fellow board members at the time. The image shows the filler neck before welding on the fitting for the uberdruckventil.
Aside from the Fabcar modified oil tank, the system comports with Race Department practice for the 2,3L "ST."
2 Attachment(s)
Suspension restoration to factory finishes - part two
Steering rack and axles were given a similar treatment to restore them to factory finishes.
1 Attachment(s)
Starting to look like a 2,3L ST
A belated Happy New Year to all from Another Hot Rod!
(No, this is not Curt Egerer's garage, notwithstanding the Mars Red turbo quattro coupe in the background).
3 Attachment(s)
Reinforced bananas correct for 2,3L ST?
Ed: Thanks for asking as it is an interesting question, the sort that factory documents fail to address as far as I know. 70SATMan asked a related question a while back.
Here is what a fellow 2,3L enthusiast in Germany has to say on the subject:
"Hello Tom, original the swaybar consoles on the ST 2.3 are the same like 2.2 S - untouched! Not boxed and not welded anything around, also on the front swaybar, all this modifications started with the 2.5 l, 1972.
Also the rear bananas are original, modifications came also 72 and they are the same like on the 2.7 RS from 1973. If you want to race your car in club races etc. I would do the mods if not I would leave it original."
No doubt many of the 2,3L cars were updated, perhaps out of necessity over the course of a few race seasons. As a note of interest, I am told that reinforced bananas are not legal for historic racing in Germany for the C and D series cars and that the mods put the car up a class to run with the 2,5L ST and the RSR.
4 Attachment(s)
ST rear center panel - lower mounting tabs and exhaust cutouts
Cornpanzer requested some detailed images of the:
- lower mounting tabs for the rear center panel on the bumpers and the panel itself
- the contour of the exhaust cutouts and depth of flange on reverse side
These should provide answers to all your questions Dave but ask away if you have some more.
