Originally Posted by
sonett43
never a need for a post in a small space like that, maybe steel or an LVL, but if both ends are properly supported to a footing, you can always find a way to eliminate that structural wall and the post.....maybe not cheap or easy, but still can be a DIY project....termite damage, that's another story.
Still, the look of that old garage is so much cooler than anything you'll get today, and especially when comparing to steel.
if you want to rebuild the lean-to, all the better, enlarge it, make it better and bigger, taller, deeper, you will still be below the cost of a new steel building and can make it exactly what you want
