Various Parts Wanted for 1973 RSR
MIKE CURNOW
mcurnow@comcast.net 484-288-8075 home 484-904-6881 cell Phila. Area
1973 CARRERA RSR 2.8 & 4-CAM SPEEDSTER PARTS NEEDED
RUBBER BUSHINGS for THE MFI PUMP MOUNTING PLATE - 911 113 121 00 OR 901 343 783 00, I THINK
RSR 92MM MAHLE CYLINDERS AND PISTONS - TRYING TO COMPLETE A BROKEN SET - (1) NON CE GROOVE CYLINDER - (3) CE grooved cylinders
RSR MECHANICAL TACK CABLE - OR AT LEAST THE LENGTH OF THE CABLE - 911 641 511 02
ORIGIONAL 1973 RSR DRIVERS SEAT - black cloth , no headrest, no adj. 911 521 903 02
RSR ECCENTRICS FOR THE REAR SWING ARMS - to adjust bannana - they have a hex head , not allen 911 333 145 00
RSR ECCENTRICS FOR THE REAR SWING ARMS - to adjust bannana - they have a hex head , not allen 911 333 145 01
NUTS FOR ECCENTRICS
SIDE 1/4 WINDOWS ALUMINUM TRIM LOOKS LIKE THE 1/2 ROUND TRIM AROUND THE WINDSHIELD
RSR QUICKER STEERING RACK AND PINION
HEINZMANN FIRE EXTINGUISHER SYSTEM - HANDLE AND CABLES ,TUBING, BRACKET BETWEEN SEATS
ONE STEEL HIGH BUTTERFLY AIR HORN , CHROME PLATED
FOUR HIGH BUTTERFLY AIR HORNS, STEEL WITH GOLDISH PLATING
RSR 915 TRANSMISSION SHIFTER - May not exist for a RSR ?
1973 RSR BEHR OIL COOLER - in & out holes-30mm- on end facing passanger side of car
RSR RUG KIT
DARK BLUE CARRERA SCRIPT - APPROX 69 inches long , PORSCHE AND CARRERA SCRIPT FOR ENGINE LID & BUMPER TAPE
picture of the SHEET METAL FOR A 1973 RSR BEHIND THE CENTRAL MOUNTED OIL COOLER
356 4-CAM ALLOY STEEL WHEELS - Wide bolt pattern, 356 A & B
HIGH BUTTERFLY AIR HORN __ MADE FROM ALUMINUM
1973 RSR OIL COOLER END CAP WHERE THE IN & OUT HOLES ARE AT.
