5 Attachment(s)
Koni front shock replacement
So, after getting my car back after essentially 8 years of hibernation/restoration I started driving it and shaking down all the little details. The car had a pretty loud squeaking noise after the first few hours of enthusiastic driving from the front left, and this could easily be replicated by pushing down on the front driver's fender. Further examination showed oil leaking from the front shock. Enough to produce drips after a half hour drive.
The struts themselves looked original, had intact paint and were not touched during the restoration except for a thorough cleaning, although the rest of the front suspension was rebushed, repainted and replated.
Not sure how clear it is in this photo, but the shiny look comes from oil everywhere.
Attachment 526049
So I called Jason at Paragon, and ordered a set of Koni front strut inserts, 86-1638 and a set of rears as well. My rears are date stamped 3-73, and if I'm going to do the fronts, I should probably do the rears for a balanced ride.
So these showed up by UPS a few days later.
Attachment 526050
They come with Koni's hieroglyphic instructions, but fortunately the whole process is pretty straight forward and Paragon has a bit of a blurb on their website. However, there are a few tricks and things not mentioned, so I thought I would go through the procedure here for people. One thing to note is I built custom cafe racers and other bikes for many years, and so motorcycle forks are my specialty. That made things easier perhaps, but most importantly, I had the right tools.
To really make this an effortless job, you need a pin spanner wrench, like the one I have been using for years. Useful for many other things too.
Attachment 526051
I bought mine used (actually never used as far as I can tell) on Kijiji years ago, but I see Amazon still sells them for C$65 or so.
So the first step is to loosen the wheel studs and then jack up the car. I used my low slung Canadian Tire Motomaster pump/lever jack under the rear control arm point and jacked the car up until I could get a jack stand under the normal driver's side jack point. Remove the tire.
Then you undo the 22 mm bolt in the trunk and pry the big yellow washer off the rubber mounting piece. Note that that washer is keyed to a slot in the strut and that there is another smaller washer on top of it (that goes between the big washer and the nut) that is also keyed. The little tab on that points up (i.e. the nut goes over it). My hardware is all new, so removing was easy, but if the shaft starts rotating before you can loosen the 22 mm nut, just clamp the big washer in some vice grips and you'll be fine. It's keyed, so it stops the shaft from rotating.
Once you have that stuff out of the way, you can push the strut through the mounting bushing with a screwdriver or rod of some sort. These are hydraulic dampers, they only control rebound really and they don't pop back up, so when you push the shaft, it stays wherever you pushed it to. Once the shaft is clear of the mounting bushing, reach underneath the fender and push the shaft down until it is more or less flush with the shaft cover. this is the top orange sleeve that keeps your shaft protected. You can now remove that sleeve, even without tilting the shock out of the fender. Once you remove that, you'll see a black rubber bump stop that looks like the Michelin man. Note that the round part faces down. Remove that. There will also be a white washer with pie shaped embossed patterns. This is to prevent a bottomed out shock from sucking vacuum. The new Koni strut inserts come with this piece and a new rubber bump stop.
OK, so far so good. Now turn the steering all the way, as if you are making a left turn. Make sure your steering wheel is not locked as the force you use in the steps below could potentially break the steering lock. I found this angle was the easiest way to tilt the strut out of the fender later on.
So you should be looking at something like this if you have the original Koni shocks. Note that the gland nut (the thing with the 2 holes for the pin spanner) is chewed up with pipe wrench markings. This suggests I'm not the first person to go in here some time in the car's 47 year history.
Attachment 526052
This picture is what it will look like after you loosen the gland nut. But that comes in the next post.
Attachment 526053
Now go have a coffee, because you'll need your wits about you for the next steps. I'm going to get one before typing further.
