What does this number mean?
1064556
It’s written with chalk under the dash pad over the speedo. It’s not the production number that usually is written behind the kneepad?
1064556
it is the correct number of digits and format to be a production number - (at least after the stopped using the chassis number as a production number in about 1969(?)) They were written with crayon on top of the dash as well as being stamped into the dash under kneepad
However, if it is, it belongs to a 1976 coupe on my understanding of production numbers - 1 for 911, 0 for coupe 6 for the year and 4556 for the 4556th coupe of any sort made in 1976 model year
the best crosscheck would be to see what is under the kneepad and see if it matches
It should be the exact same production number stamped under the kneepad below the radio.
...not always !Quote:
On a '69 911E I had the two numbers were different:
The dash crayon number is 1092826:
http://home.clara.net/andyjboy/Productionnocrayon.jpg
& the stamped production number is 1092823:
http://home.clara.net/andyjboy/Productionnostamping.jpg
on my '72 the numbers are the same. I seem to recall in another thread that it may have varied in earlier years? :confused:Quote:
Originally Posted by J-P
Maybe it's a '72 thing, then. On my 72S both number match.Quote:
Originally Posted by 911scfanatic
From memory the crayon number on the dash is the same as the VIN for swb models, whereas for the lwb '69-'73 models the crayon number should match the production number (stamped into the sheet metal below the radio opening) but this number is not the same as the VIN.
My point was that the Factory did make mistakes...
you will likely discover the meaning of life or the fountain of youth before you will get that mystery solved :D
..just guessing...:Quote:
Originally Posted by boxster03
"Keep in mind the cars were not produced in a numbered or sequencial order. When a car needed a special part it was moved off line until the part was attached, or rolled back into line after a change out of an engine or transmission. "
(Quote taken from bobs67S post about the 64/65 production)
...yes..........but the production number is supposed to be "the number" that is allocated to each car before it is made and then carried on right through production regardless of whether it has changes to it, regardless of the options, engine specs etc - ie all coupes in made a particular year should have consecutive production numbers (regardless of specification or when they were actually completed) based on when the order was first processed at the start of the production process. In my view it is extremely unusual (but obviously not impossible) for one car to have two different, and very close, production numbers written or stamped on it - it does not mean that both are correct however.Quote:
Originally Posted by 911T1971
It could be a "friday afternoon" car where a simple transcription mistake was made in either the stamped number or the crayon number.
I guess it is also possible to have 2 production numbers allocated to one shell, say if the car had been remanufactured, but they would be a long way apart
However I am aware of a car that started out in life as an "S", was used for various special duties by the factory and then, in a later year was converted/remanufactured by the factory to a genuine RSR. Its chassis number and production number however are of its original identity as an "S", regardless of the fact that it went through a complete new production process and was subsequently delivered as an RSR (with all the goodies but without the RSR identifiers in the chassis number). Porsche records however show both identities, as an S and an RSR against that number. The only hint is the identity tag has been stamped with various different numbers and letters that should not appear on the one tag - ie a chassis number from one year (unusually stamped in two different postions) and type and date code numbers from another year and specification of car.
