So the one job I was dreading has bit me on the ass...
Fitting the hood up for gaps and getting the lock to align properly has left me with a hood that won't open! The spring loaded pin just won't let go (the finger trigger part is clearing). Cable isn't connected so it's in the default open position. I've banged and pulled, jacked the car up unevenly and pulled with no luck. Obviously I've got it cocked or loaded to one side.
Not sure where to go with it now? And advice would be great...
