Originally Posted by
smedley
Lee,
Your photo is confusing and we are all going to need some more info on your car. A '69T?
Your photo shows the ignition on the RIGHT of the steering column...additionally the dash fascia covering appears to be '72-'73 vinyl.....to my knowledge all production '69 900 cars had vinyl "waffle weave" on the dash fascia. Additionally you have another accessory pull switch adjacent to the speedo reset knob. That looks to be generic Bosch, but not standard factory fare. Can't explain the hole by your finger as your dash appears to be completely re-arranged from factory original. What is on the left fascia where the ignition, headlight switch, and emergency flasher switch would normally be??
