3 rings per cylinder/box. Let me know what you may have! Thanks
I believe 901.103.185.50 is the part number...little confusing on the research.
I have 5 NOS sets of what I believe are the correct rings for a 2.0 litre 'S' engine having checked an original Parts Catalogue (901.103.901.51), £125 GBP plus shipping from the UK (PayPal +4%):
Terry you need 901.103.901.01.
Tim, your rings are 80.5mm. I could really use one set of those if you could split them. I just a few days ago opened up a pack of NOS 80.5mm rings (packed in 1998) and the oil control ring was in two pieces, well 3 if you count the spring.
andy
Andy
I don't have a parts catalog to work out of, so the different numbers are throwing me off. I originally thought 901.103.901.01 was for an S but then thought it was for a non S 2.0 So I need 80.5 or 80.0? Whats the difference between the number ending in 01 and 51? What is 901.103.185.50 for? I think I need 1.5 1.5 and a 4 comp ring? thanks for the help!
I can post some info from PET later on. 901.103.901.01 is for 80mm 911s 1.5,1.5,4mm set of rings. Tim has 80.5mm 1.5,1.5,4mm sets. The individual rings have their own part numbers also.
Andy,
Thanks for the info. I tried to track down using the individual catalog numbers but that was like herding cats. So, Tim's ending in 51 was the marker for 80.5? Then these won't work for me so I hope you can get together with him to fill your need. My search continues.
Thanks for the clarification Andy (and Terry sorry for the confusion), had another look at the Parts Catalogue and yes ending '51' is 80.5mm for 1967/68 911S......everyday is a school day!
Andy I would prefer to sell as a job lot because I have no need for them now although if anyone else expresses an interest for some then maybe we could sort something out.
eBay item 265446664523
Rings found. thank you all for input.
Some stores are selling aftermarket sets as this part number. I'm no pro builder but the advice I received from professionals was not to use deves rings.
