just to let you know there is a 10K euro reproduction out there limited run , not from me or DANSK so relax
but let me know if you are interested 2-3 sets left
M
M
So what car would those be appropriate for?
Bob B
early 901 / 911 hmm I belive up to chassi number 700 ish but not sure
Marek
I think change was later too - possibly mid-1966 when a more efficient design was installed. Would be interested to see date of change confirmed in eg factory documentation as suggested
See this thread. All the way till the end of 66
https://www.early911sregistry.org/fo...t-system/page5
Richard
Arent these available for 6K from Freisinger?
So my understanding - which may be incomplete - was that the new manifolds/exchangers were fitted to new cars from mid-1966/the start of model year 1967. There was also a replacement/recall programme for existing cars that started about the same time and looks to have run into calendar 1967. Does that sound about right? Thanks, Robert
Robert, yes, the "new manifolds/exchangers" were developed for the '67 model 2000S (911S) engine, and introduced with that model.
The same exhaust system, but with restricted outlets, was installed on '67 model 2000 901/05 engines until the 901/06 engine was introduced, in Nov '66.
Jon B.
Vista, CA
And Jon I presume the real reason to have the restrictors on the “normal “ until the new engine was introduced was to lower the power output of the normal otherwise it would have been too close to the S as there are plenty of examples of early engines even with almost no modifications making close to 67S power figures- or at least close enough to worry the sales department about how many of the new S they could sell or what price point they could achieve
absolutely...to quote the service bulletin M16/66...
".....The above listed heat exchangers may be used as replacement parts in Type 2000 engines up to Engine Nr. 909 927, as indicated in Service Bulletin M 14/66, although this will result in increased engine power output."
So, which version was used from 68 on? Or are the 67S heat exchangers unique?
Hugh, I think that's the common view and probable reason, although I'm not sure if Porsche ever publicly stated that.
The 901/06 engine was developed for a better driving experience in the lower engine speeds.
I believe the '68 models continued to use the '67S version unaltered.
The basic design continued until, I believe, the '75 model year, but there were occasional changes to the heat shrouds and possibly the header tubing too.
Jon B.
Vista, CA
Just came across some images of these early heat exchangers in my 1965 edition workshop manual.
Are these heatexchangers still available ?
Yes I got a set on stock
Pls send me a email to early911parts@gmail.com
Marek
