I need:
1. Set of rod bearings
2. Engine gasket set
3. Rod bolt/nut set
4. Rear layshaft thrust bearing
5. New timing chains
6. New chain ramps
Let me know what you have.
Thanks.
I need:
3. Rod bolt/nut set
6. New chain ramps
Thanks.
You need to specify the rod size you need. Std, .25 under, etc.
I will check, I might be able to help you w/ the NOS rod bolts/ nuts.
Richard
Richard, std sizes.
I've got a set of factory rod bolts & nuts available.
Mike, PM sent
Use ARP bolts, they are the same price as OEM but reusable
unlike OEM stretch bolts.
andy
Package deal. I have 2 chains with Master links, ramp set, 2 original style tensioners with spacers. Make me an offer.
Bobby Smith
member #299
You can get ARP bolts just about anywhere, EBSracing.com for instance.
They're in Reno.
andy
Glyco rod bearings are garbage. Buy the hand made steel ones from Pauter. PERFECT.
