Hi Guys,
Anyone have a good source for replacement bulbs for the factory below bumper driving lights?
Also any pictures of the correct placement for a rear fog light for a 67. Mine came mounted but looks too close to the exhaust?
Leonard
Hi Guys,
Leonard
Rear fogs
Thank you John that's exactly what I wanted to see.
Do you know if there is a bracket or does the light bolt directly to the rear panel via the chrome base?
Mine came with a bracket that mounted it below the panel with one of the union bolts between the rear panel and the bumper...obviously now, wrong location.
Thanks again,
Leonard
Yes, there is a special bracket with a approx 90 degree bend. I will take a pic of mine and post for you.
Thank you John. You're a big help.
Leonard
This is what you are locking for. Mine is yellow zinc coated, I belive blue(silver) zinc is correct.
JOhn
Is there a part number for that rear bracket?
In my PET its pictured on illustration 905-10, with the indicator lenses, fogs etc. It has # 26 in the picture. The strange thing is that the part numbers for the bracket and backing plate are not listed, all the other lights and lenses on the illustration is listed with a parts number. Sorry I could not help.
Found it in the SWB PET, its the exact same bracket in the illustration. Parts number is: 911.631.125.00 "angle", the backing plate has parts number: 911.631.126.00 "support"
Fantastic John,
What a great help!
Now....what's the tube the "angle bracket" is touching in your picture of the cad plated parts? I have one just like it and remember it coming from the engine compartment. Of course now, years later, I can't remember where it went. Air cleaner vent or???
Thanks John for posting the pictures. :)
Leonard
