I got this mesh at McMaster-Carr. I formed and painted it.
thanks, guys! I'll check out the options at mcmaster-carr.
Added Audette LED headlights, easy on easy off spare set of fog light covers with butterfly nuts for cooler weather. I have duel oil coolers in the front fenders. The little lights are LED daytime running lights. And I picked up my second set of 6X16 Fuchs powder coated in Army green. They will be mounted with super stickies.
Modified some 356 tail pipes to exit from the rear panel on the 912...
https://hosting.photobucket.com/imag...720&fit=bounds
Chris
Additionally...I was donated some "R-style" lights, but decided not to fit them onto the ModRod. So with a backing plate to fill the factory exhaust outlet and some wiring, I now have an auxiliary brake light...
It's bright !...
Chris
On my Targa bar…
Restored with Cerakote
Attachment 587703
My favorite thread on here, so much inspiration..always love when I see it getting updated !
Antoine
I’ve been doing this about 10 years now. When ever I’m installing light weight Amber engine fiberglass shrouding, I was confronted with how to attach it. Doing restorations I saw the way the factory did it and decided to try another way. I got countersunk soft 1/8”x1/8” rivets and a rivet squeezer, along with 6mm weld nuts. I drill out, and plate the weld nuts to modify them into anchor nuts, then fit and install.
