1 Attachment(s)
Horn Pad Install Question
My 914-6 came with an aftermarket Momo steering wheel and I am going back to stock wheel. Pulled everything off and found a brown/white wire in the column (see below) is this extra because the 914-6 wheel is the same as the early 911's and use the contact pin correct? I did search this site for answers and found a post from Ed Mayo that said the columns had extra wires in it. So getting back to the stock wheel install there is no wire to connect to the horn pad right, just slip in the short contact pin and twist the horn pad on!
Attachment 310162
