Good morning all! Wondering if anyone has found a solid fuel injection conversion kit to fit a base 67 911? Looking to get away from carbs and add some modern connivence to a wonderful old car.
Has anybody done this?
I don't have any experience with it but I believe Al Kosmal makes a kit to go EFI. Were you planning to do EFI or MFI? https://www.x-faktory.com/services.html
Jenvey in the UK have recently made an EFI system that looks like carbs, they have been around injection systems for a while but no personal experience.
https://store.jenvey.co.uk/heritage
Check out these two companies.
https://rasantproducts.com/
https://www.clewett.com/
I'm running a Electromotive ECU, TWM throttle bodies and crank fire for over 10 years. It appears Electromotive is out of business. A properly tuned EFI system is a very nice upgrade.
If I were to do it again, or upgrade the setup I have I would go Motec for the ECU.
rasant is no longer in business.
When did rasant shut down? I left a message on their answering machine 2 days ago.
After doing a search I can't find anything that states they are out of business.
Thanks for the suggestions. Ill do some research now
