Looking for used Fuchs wheel centers for '76 flat Fuchs that need refinishing...
Thanks for looking!
-Chuck
Thanks for looking!
-Chuck
Just to be clear on what you are looking for - there were 3 different caps for flat-6 Fuchs. Early flat-6 (through late '73) had 66mm center hole and used the same 3-ear caps as the deep-6 Fuchs. Later flat-6 (late '73-on) had 70mm center hole and used the ring-mount caps. Later ring-mount had a pair of small holes in the face, early ring-mount caps had no holes. I'm not sure when they changed from no-holes to holes, but I think it was after '76. So I assume you are after the no-holes version for a '76. May be hard to come by.
Yup.... Need the 70mm cap.... Not sure if I need with or without the 2 holes, but I assume both would work...
Thanks for the clarification,
-Chuck
Yeah, hard to say whether the holes or no-holes is "correct" for your application. But either will fit. The no-holes caps are a bit tougher to find.
I have this set with ring attachment, one has the 2 holes for removal. I would sell for $85 shipped in USA.
Attachment 553221Attachment 553222
Mike,
Those are just what I'm looking for! Please send me your Paypal address... (Krause13@pacbell.net)
-Chuck
Centers purchased!
