https://ebay.com/itm/194448345198?ep...kAAOSwDo1hbaKI
Whatever the cause, you are going to have to take the engine apart.
Bruces book is great, but Wayne's book gives clearer instructions for a rebuild. However, my recommendation is that you send it to someone who knows what they are doing and has access to competent machine shops.
I'm going to buy the book, and I'll get my hands on it to disassemble it. My intention is to disassemble cylinder heads and from there to be able to see the crankshaft. Once I'm at this point and without fully "opening" I'll decide if it's worth having the mechanic work on it. A reconstruction of this type of engine... how much money could it take? 10/15K? What work could I do (disassembly or whatever) that is "simple" in order to lower costs? These days I will buy the motor support... I will try to see the book in bookstores and if not I will buy it in amazon! This is decided ... If anyone wants to give me advice or think of things to try on the engine. I'm your boy! I can post videos of anything! And RS/62s thanks for the advice! The mechanic "doesn't have much enthusiasm" to open this engine... So the way I think is still to buy another rebuilt engine! But equally, we want to see the state of this and repair it over time if it is repairable.
ummm I tried but they don't send to the Canary Islands from that link. A shame because it's extremely cheap...
I have removed the plastic casing. So far all the screws have come out fine. When I take them off I put them back in place. The idea is to lighten weight and this week buy the motor mount. I have also removed the top and bottom covers. The screws came out fine too! The next step when you have engine support will be to remove the exhaust manifolds.
esta herramienta es correcta para el desmontaje ?
https://www.ebay.es/itm/325145691838...EaAgRvEALw_wcB
Attachment 575267
Attachment 575268
I have loosened the two nuts...these days I will upload it to the workbench or support...I don't know what to call it.
To remove the second nut... I had to disassemble the tensioner... Pass the wrench and reassemble the tensioner to block and loosen it. I thought it would be a much more complicated job. 20 minutes to my surprise
where the wrench is located, when disassembling the "pinions" I found a large, deformed metal washer. I understand that it will not "have" to do with the "axial clearance" but .... if it is a symptom.
the "rusting" nuts have come off easily on that same side.
Attachment 575270Attachment 575271
Many shops charge $20-30k for a rebuild. Parts and labor.
I know, I mean... I know that I don't take care with the camshaft when disassembling since it is intended to disassemble the entire engine. It depends on the state, it will be sent to the mechanic to be assembled... In the same way I am still looking for 2.7L engines. The next thing I will do tomorrow will be to remove the rocker arm tower... My intention is to get to the piston. Once there, remove it and observe "superficially" the crankshaft. Your advice is valued! And thanks for the information on the washer...
I have removed one of the complete heads. The pistons are dirty, but they are fine. I keep observing the axial movement. I put the cylinder closest to the rear of the engine in the position furthest from the block...I make the movement and it is observed how there is movement in that cylinder....I repeat the same process with the piston next to it. I don't see movement. IS IT PARTY AT THAT POINT? Or can it be due to another cause? I will remove the pistons to be able to observe better....
Attachment 575319
I have removed two pistons. The ones closest to the exhaust part on the left side. I'll take out the third one and I'll put "elastic".
I don't see much interest in this post so I won't "load" the system with "many photos"...
I have also removed the studs from the front part to be able to raise it to the support... I intend to use the generic support now that the motor weighs little. The asparagus gives me little confidence... Are the motors really held with the official support on two asparagus?
To separate the crankcase, it cannot be mounted to an engine stand on both sides.
Be very careful when removing the large sensor above the right chain housing, so that you don't crack or break off the attachment area on the case.
Jon B.
Vista, CA
