Road Tire Recommendations
OK, I give up … can not find 215x60x15's Yokohama AVS Intermediates for the back of my Carrera flared 73-S.
I love them - have had 4 sets since 1990...
Yokohama has discontinued them AND I didn't get in on the Tire Rack blow out.
So... I'm looking for an 'Ultra Performance' tire that will give me the same characteristics as the AVS's in the same size (215x60x15's rear and 205x60x15's front) AND are not toooo expensive (I'm pretty hard on them plus 2 degrees of neg. all-round doesn't help the ware either)
Will not be using them for the track ( have another set of 7's and 8's with Kuhmo DOT's) and certainly have no concern if they look period correct.
Please help me with my AVS Intermediates replacements.
Chuck
Hello
The only comparable tires are the RE 71 NO, however in germany they run around 240 € a piece wich is for many people to expensive ( some shop 4 tires for there Porsche with that money ).
The german Yokohama catalouge still shows AVS ( 50i ? ) tires for use on mercedes and audis ( 93 rate plys ). Must check on tirerack or yokohama.com
Grüsse
Chuck, you may want to try the Yokohama AVS ES100
Tire Rack has your size - 215/60/15 for $77.00/tire
