3 Attachment(s)
73 S - engine wiring question please
Referencing the attached photos, may I please ask for clarification of several connection points for the engine harness that runs from the CDI box to the distributor and coil. I have a wiring diagram but would still like confirmation/direction. I understand the CDI box end and those three connections - my question pertains to the four connections at the opposite end of the harness and the four connections shown in that photo. The connection with the green tape was plugged into the purple/black wife female connector that I believe plugs into the male/spade connector at the distributor body. The ring connection to the left of that would seem to connect where there is a threaded hole in the engine fan housing...just not sure, but I don't see any other possible connection point within that proximity. Lastly, the two connections at the right end of the harness...the blue/yellow wire with a boot and the ring connection. Blue/yellow would seem to be the + connection on the distributor coil, but unsure of the ring connector. Thanks to all.
