Immobilisers - Required for Insurance
G'day All
So I'm in the final yards of the electrical system of my car. The complete harness was removed during my resto and the re-installation has provided me with hours and hours (and hours) of entertainment. On the plus side I removed an eighties era alarm system that never worked, repaired potential failure points, upgraded the fuse boxes from the old ceramic jobbies to ATO/blade fuses, and managed to remain true to the factory wiring system/diagram for any future custodian. I even managed to fix my very intriguing washer motor that never parked (turned out to be a later motor with 5 wires rather than the 69's 4 wire system), thanks to the wonders of $12 relays it now works and parks perfectly. And I wired in a couple of sneaky anti-theft measures. A little switch here, a little switch there...
And then I notice my insurance policy. They require an immobiliser. I gave Lumley a call to discuss and indicated I'd wired in my own effective immobilising 'system'. All went kinda silent and the eventual response was that 'for everyone's benefit' a system should meet the Australian Standard (AS/NZS 4601:1999). Given that Australian Standards are something I work with and audit against everyday at work, I actually understand and respect the call. So off to the internet for research...
I don't want whistles and bells, flashing lights, central locking, pagers, GPS tracking, bla bla bla. So I've come up with the Dynamco 205 transponder immobiliser (sometimes rebadged as a Cyclops) http://www.dynamco.com.au/products_p...php?model=P205 What I like about this is that it's passive - the transponder does not need batteries or buttons pushed, it simply senses me/transponder and allows the car to start. When I walk away after locking the car "old skool" with a key ;) the system senses I've moved away and automatically arms... I don't need to remember anything. Should the transponder fail or I lose keys, there is a PIN that can be entered to overide (can be self-set so I won't forget it). So I ordered one. Now is a perfect time to wire it in as everything is still exposed and accessable - I won't post what circuits or where it will be installed etc, but it is relatively easy.
So putting the cart before the horse as I so often do, I wanted to ask about what others are doing and what brands/systems are preferred. Any horror stories? It's also perhaps a timely reminder that these cars aren't getting any cheaper and insurance really is a bit of a must; so is complying with their requirements lest they look for 'get-out' clauses when you need to claim...
Cheers
