Help required - engine breaking down at 6000+ rpm
Hey guys,
My race car has developed a habit of breaking down over 6000+ rpm. This has never normally been a problem in the past, however I did not notice that when I had the lights or wiper on when racing the problem occurs also.
It only occurs when the car has done a few laps and starts to get a little warm. Car runs on Webers.
I changed the coil, with no change to the problem.
I do run a small Odessey race battery.
Plugs are new and dual heat range.
My best guess is one of the following (what do you think!?!)
1. Altenator is not charging enough at higher rpm leading to a voltage draw
2. Leads are shorting out somwhere when under load
3. Electrical gremlin somewhere (even though car was restored 1 year ago)
4. Battery cannot cope with voltage required if slightly down on charge
The breaking down does not cut power all together but it creates a pretty good miss, so it does still spin out, albeit slowly and far from smooth. Motor has previously revved to 7500rpm with no problems.
you can see the videos at www.youtube.com.au/aewebster
Open to any thoughts, as our 1973 2.8 is also doing the same thing in certain conditions too!!!
Thanks in advance :)
Just a little too coincidental...
Alex,
I have to concur with Kenikh & Chuck...
The fact that you've got two different cars doing the same thing tells me it's an "external factor", meaning;
1. You've gotten into a bum batch of gas - do you buy your gas by the barrel?
2. You might - as Chuck suggests - have a moisture issue common to both cars...Have you looked at both your distributors lately?
3. When was the last time both of your alternators got checked/tested?
4. A small battery like that, when they get older, will cause this too...I use a small, cheap lawnmower battery, and I change it constantly.
5. I know you don't want to hear this one, but; check every single ignition connection for surface corrosion, and tightness, if everything else seems to check out.
Hope this helps :D let us know what you eventually find.
Cheers
Thom
