cost to rebuild 2.0S engine?
i know in general a rebuild for a 911 engine can be up to $10K depending on the engine. i know some cases require more machine work than others. i know some parts may or may not need to be replaced. i know some go through some extensive modifications. so i am asking for some costs specifically to the 2.0S and rebuilding it to factory specs - nothing fancy - no HSR spec'd engine - no 2.2S upgrade - no race fuel only engine - just factory. thanks so much.
porsche power plant pick pocket protection
I have (copies) of receipts for a 2.0 full rebuild...with parts, machine work, clutch and trans work....$12,000.
I had a top end performed on my car...and tuned to perfection for $6,500. For what you have specified, without major problems....$11,000 is a good figure.
Ask the best in the west, 2.0 and 2.5 liter engine guru Frank Beck what he would charge. He made my car quick and dry. I know that he rebuilds 2.0 race engines every other VARA weekend for $15,000 and up.
The guy knows his stuff. Shawn.
