901 Transmission Rebuilt - problems with blocking
Hi,
I had my 901 transmission rebuilt by a very reputable shop that I've been going to for a number of years about 5,000 miles ago.
The problem is that I am getting blocking in 2nd and 3rd gear on a regular basis (both on upshifts and downshifts). Is this normal after 5,000 miles? My only experience with a newly rebuilt transmission is on a 741 for a 356, and that one was smooth as silk after 3,000 miles. For now, the mechanic is recommending replacing the gear oil with normal motor oil, drive it for 10 miles or so, and then replace with the correct gear oil. Seems like its worth a shot before we pull the trans again, but I'm not sure how effective this will be.
Any thoughts?
Thanks for your advice.
Mike
All of the above are good possible solutions, another consideration is what oil is in the box now? Some oils are TOO slippery and don't allow for enough friction to let the synchro band work. 4th and 5th may not have been as affected if those parts weren't replaced. If easy cures like oil and shift linkage don't do it then it must be an improper shift fork/ shift rod adjustment.
