1 Attachment(s)
Rear Main Seal In Too Far?
Just sealed up the case on a rebuild on my 73 911T, and I think my only mistake I know of is that I forget to set the RMS .5mm proud of the case. In fact it's about 2.73mm inside the outermost lip of the case. So 3.2mm too far in vs spec. I installed dry on the OD and oil on the ID. I have read every thread and can't come up with reason to replace it, other than there must be a reason for the .5mm spec. Leave it alone or replace? It's the RMS that comes with the Wrightwood Racing Kit. Don't mind the time or cost to replace, but is there a reason? thanksAttachment 579211
