LWB Horn Grille Seal Details?
I'm about to get my horn grilles back from the rechromer and would like details as to how to correctly reattach them to the car. These are the standard, 2-screw LWB grilles, not TTG fog lamp grilles. Specifically, what are the correct mounting screws and clips, and how does the rubber seal attach to the back of each grille?
When I took the grilles off my car I noticed that the original rubber seal (sort of blue-gray) ran across the top edge of each grille but had been cut at a bevel at either end. The replacement seals from Stoddard (black) are not beveled.
Apologies up front for (1) not being able to find this in a search (2) not photographing the parts when I removed them from my car.
TIA
