2 Attachment(s)
Options to re-bush early 901 transmission carrier with rubber-like replacements
Hi all
I have what I believe is an early style 901 transmission carrier which came to me with one missing and one degraded factory bushing. I would like to re-bush it with the most factory-like inserts, am not looking for anything approaching solid or high durometer poly. I've had a hard time finding the right part as most of the rubber mounts are pre-bonded to their 'flange' such as : https://www.partsklassik.com/p-513-e...ion-mount.aspx My carrier is the type that does not accept the flange, the bushings are installed directly to the steel stamping.
To the best of my knowledge these are one option https://www.pelicanparts.com/More_Info/PEL-RSRMTM.htm
as is the Wevo, at a significantly higher cost, and I would guess with more noise and harshness? https://www.wevo.com/Products/Chassi...STransBeam.htm
Any other options out there besides sourcing a good used carrier, rubber included?
Photos of my carrier are attached.
