Website Suggestion
Much discussion has been offered regarding Registry events. Would it be possible for our webmaster to add a calendar? That might drive a bit more regular scheduling of events. I offer this as an example...
Here's the web site for my PCA region:
http://www.pca.org/red/
If you click on "Upcoming Events", you see this calendar:
http://www.calendarwiz.com/calendars...p?crd=redwood&
Hopefully this idea is of use.
That's'a very good idea Peter...
We've tried it in a couple of different forms...
The problem comes, with only 4 on the board, when there's not enough time to get to it... and up-date it :o
If someone would like to volunteer to go through the Porsche and vintage car mags and come up with an ever-updating calendar of local, national, and international events... we would be tickled to death... :)
Thanks very much for your input...
Any takers ?
Cheers
If the webmaster can build a calendar function, I can fill it...:)
I will help out if I can.
The message board has a built-in calendar. Registered users can add events.
Calendar
I tried to add an event :)
no go :confused:
any reason why not? :(
Try again. It should work for you now.
Works - thanks
Works well .. thanks .. :D
Are all the birthdays necessary? :confused: To me, they just clutter up the calendar and make it difficult to pick out actual events.
TT
