Koni rear shock - disassembly question
In order to have the lower portion of my rear Koni's powder-coated, I see that the cylinder is seemingly held in place with a screw-on collar not unlike those on the front struts. Car is a 1970 911-S with later (replacement) Konis installed. With the collar removed, will it be as simple as pulling the cylinder up and out as I did on the fronts, or is there 'trouble' lurking inside the tube...just never did this on the rears and would appreciate thoughts. Thank you.
