anyone else experiencing this ?
nope but this is also interesting.
btw i got your mail
Nick,Quote:
new sent pm not showing up in sent box
I all seems to be working OK on our end...
However,
You can go to the bottom of this (or any) page and click 'Contact Us' in the blue footer... That will get you to our tech support...
Hope this helps,
cm
Hmmmmmmm..... ?
- Click on 'Forum Actions' in the above header...
- Click on 'General Settings'
- Go down the menu to 'Private Messaging' and see if the last option is checked....
Hope this helps,
cm
Chuck,
Thanks for your thoughts. Last night I did go back to the PM Notification page and noticed my PM limit was 50 and I had 61. So I thought I must have to delete some PMs below 50. But then going back to that page today and now my limit has been bumped up to 1000. So I'll see if that works once I send another PM.
Attachment 365240
Chuck,
FYI - Following your suggestions, I scanned the Private Messaging options and found one that was "OFF". So its turned ON and should correct the problem. I don't know why it was shut off.
Attachment 365241
