I didn't really know where to post this, but you can see how I spent my afternoon with a 3D printer.....
Attachment 281842
Attachment 281842
Now that loks like fun.
What software do you use with this printer?
Ted
This was done with the stock Makerbot software - Makerware. http://www.makerbot.com/makerware/
The printer was a Makerbot Replicator 2.
The .stl file was downloaded from Thingiverse - http://www.thingiverse.com
I can't take credit for doing anything more than using an existing file, but it was lots of fun to set up and print!
Attachment 574316
spending the afternoon! this world is pretty funny..
It is the first test, the cord (where each layer begins and ends in the 3d piece) is a defect to be solved, I will pass it to the front part. I think it will have a better finish... Printed in PLA. And chrome paint. There was no type of post-processing of the piece because it came out quite well! I'll do the next test giving it a high thickness filler, a white primer and finally the chrome paint... Let's see how it turns out... Someone else has been encouraged to print things in 3d?
use the Cura laminator and print on an Artillery x2 (€350)
hotend 230º
Hot Bed 80º
5 hours
0,3mm
Attachment 579148Attachment 579149
I am trying to make a functional boxer engine. I will try to make the camshaft functional. Hence, the casing and the crankshaft have the pinions and the holes... Let's see how it turns out!!
Attachment 579150
Attachment 579159
Attachment 584439Attachment 584440Attachment 584441
ummm... I made these fuchs for the wltoys that I bought (a car that surprises how fun it is).... I'm working on another version that has a hubcap to cover the central screw... When I have a prototype ready and painted I will upload it here !!
Salds
I still think that the printer is easy to learn for all of us... and they are also cheap for everything they offer you...
https://www.youtube.com/shorts/Q7wMP5bK9xw
1/28
Attachment 596763Attachment 596764Attachment 596765
0.4mm nozzle
0.28mm layer height
the first layer at 240º and the following ones at 200º to avoid shrinkage.
I have made this other chassis for my Wltoys... with some post-processing it will look good although I will surely print it again with a much lower layer height (0.08M).
a total of between 9 and 11 hours and an approximate weight with supports of 100gr
I am still very interested in this subject, so if there is someone who wants to share things in 3d etc... this is the post!
Attachment 596766
I also made this little thing for decoration. It remains to add a couple more things (the date does not go on the object) model, date of manufacture etc... If someone wants the STL to print it, let me know!
I have made this nerf bar from 1972. Fun process .... Useful for RC or model.
Attachment 596969
