7 Attachment(s)
FS: 911R Oil Tank, 901.107.750.00
These tanks replace:
WET '67 911R Fig 1/06, #60 901.107.750.00 Oil container, complete [Ölbehälter] Qty: 1 NLA
They are restoration-quality, identical copies of original tanks with correct internal tubes & baffles, rounded seams, and riveted steel necks. Welded aluminum necks are also available for a cleaner, more elegant look.
They are sold bare and require the use of:
WET '67 911R Fig 1/06, #10 901.107.640.00 Strainer tube Qty: 1 NLA
WET '67 911R Fig 1/06, #11 900.123.057.30 Seal ring (for strainer tube) [Dichtring] Qty: 1 NLA
WET '67 911R Fig 1/06, #59 901.107.037.01 Cover for breather (Cap) Qty: 1 NLA
WET '67 911R Fig 1/06, #61 901.107.176.00 Magnetic screw (Drainplug) Qty: 1 SS 91110717603 PCNA List, 2021: $29.22
WET '67 911R Fig 1/06, #62 900.123.011.30 Seal ring (For drainplug) Qty: 1 PCNA List 2021: $2.90
WET '67 911R Fig 1/06, #64 901.107.790.00 Strap (Mounting) Qty: 1 NLA
All of the hoses are NLA but can be assembled from aftermarket and Cohline parts:
WET '67 911R Fig 1/06, #12 901.107.350.00 Oil hose, Tank to Engine, U Bend (Strainer to #13 hose) Qty: 1 NLA
WET '67 911R Fig 1/06, #15 901.107.331.00 Oil pressure line, (from Engine, thru Filter, Thermostat, Cooler (frame tube exit) to Tank Qty: 1
WET '67 911R Fig 1/06, #33 901.107.338.00 Oil hose, Thermostat to Cooler (frame tube entry) & Thermostat to Tank Qty: 2
WET '67 911R Fig 1/06, #35 900.181.031.00 Flex hose for Engine bleeding (tank to ground) Qty: 1
WET '67 911R Fig 1/06, #36 900.181.032.00 Flex hose for Container bleeding (tank neck to catch tank) Qty: 1
Material: Aluminum, 5052
Finish: Matte
Weight: 1899.4 grams, 4 lbs, 3 oz
The price is $1848.32 each. Shipping within the US is by USPS Priority "2-Day" mail with insurance required.
International shipping is available.
Other available parts:
Key Words: Ölbehälter, Olbehalter
2 Attachment(s)
Re: FS: 911R Oil Tank, 901.107.750.00
John / Fubawu
I currently don't have an empty steel tank to weigh. Steel weighs 2.89x more than aluminum, so a ballpark calculation (different thicknesses & volumes) would be 1899.4 grams * 2.89 = 5489.3 grams or 12.1 lbs.
blue72s
I assumed that you were looking for the slight diagonal transition on the back where the tank starts to taper down so I took a second photo with oblique lighting to try to highlight it.
