Started my first foray into open heart surgery....wish me luck!!!
https://i.imgur.com/Js92LvL.jpg
Certainly not long hood work, but I replaced the PCM / Stereo in my '06 Coupe, as mine had really bad display problems. Purchased from a PCA member, and it appears to work perfectly. Other than a message stating an error with phone, GPS... anyone know how to clear something like that? My car doesn't have a phone or GPS or CD changer, and it appears this unit is looking for these items. Not a big deal, but figure someone here might know.
Scott
Attachment 520226
Yesterday I restored the original horn tags for our horns
Attachment 520227
Installed Sal Carceller's MAF system into my 72 hot rod running a fully rebuilt 3.2 Carrera engine
. . . on TRE's COVID-19 run . . .
https://www.early911sregistry.org/fo...s-angeles-area
Had a chance to really stand-on-it, too --- still, barely got 'er dirty . . .
. . . but we're the only Longhood there, apparently
Not in the 911, but took the 914 with a few friends for a quick ride, using proper social distancing of course!Attachment 520529Attachment 520530
Blue Ridge Pkwy Attachment 520548
After switching out my front to back tires on 3/12 in anticipation of a 3/30 track day that was cancelled… and after taking nice a mountain drive on 3/28 that involved driving on some freshly cleared snowy roads… A couple of days ago it’s was time to wash the drive off and take time to pull off all 4 corners and have a look, and clean while I’m in there….. I do this about twice a year, depending on the amount of hard drives and track days…
Considering how hard I drive my 47 year old car I try to generally smoke over the bottom and inside corners of the car: Brakes, wheel bearings, loose bolts, and (heaven forbid) any cracks at or near suspension points….
In 31 years I’ve had one A arm sway bar drop link connecting ‘U’ mount tear off, and one rear sway bar round mounting pin pull out of its bushing ….
Oh, in 1998 I had a flywheel seal and accelerator linkage coupler fail on the same day at the track, and had to be towed home… :rolleyes:
I’d say the old ‘German over engineering’ has worked pretty well for me so far…. :)
- Took the pic just before I set my jack stands….. ;)
- Go'n home from my DNF 22 years ago…. :o
Cheers,
cm
Took it on my first short drive after 6˝ months of refresh time.
https://www.early911sregistry.org/fo...6&d=1586208784
Nice Arne....... look'n good
