Guys, the original fuel pump for a 67S uses banjo fittings for inlet/outlet. 12mm X 1.5 thread.
All current replacement Facet fuel pumps use pipe thread.
Any suggestions on how I can stay W the original banjo fittings on a new pump?
Try this eBay seller
https://www.ebay.com/itm/Porsche-901...0AAOSwKfVXGEEh
Buy the Facet pump with the larger pipe thread , re-tap the threads to 12mm X 1.5 and you are on your way .
I like it! Thank you!
