2 Attachment(s)
dash crayon numbers
I've looked through the many threads on the crayon dash numbers. I didn't find any mention of crayon numbers on the passenger or right side of the dash. Just started stripping down a Sand Beige 6607 67 S and found three sets of 2 digit numbers . It looks like 26, 66 and ?. Just wondering if someone knows what these might indicate. Thanks
it's my understanding that the initials of the painters were signed on the passenger side...
yep painter or QC guys initials
1 Attachment(s)
a very late my67S you have there..are there seat belt ancors on the parcel shelf present?
and if you have the original front slam panel can you have a look if where 68 cars have the washer bottle filler opening is a closing plate welded ..from the inside there should be spot welds visible..thanks
1 Attachment(s)
For reference here is a 1968MY 911T (12th September 1967 build completion on Kardex) so presumably painted 28th August with initials:
3 Attachment(s)
Thanks for the info. moito the seat belt anchors are present on the rear shelf. They have plastic phillips head screws threaded in so probably weren't used. The slam panel looks original, there is sand beige showing where the red paint is chipped. I took a pic from underneath and didn't see any spot welds. the area looks very uniform with original under coat.
