3 Attachment(s)
FS: Weber 46IDA3C conversions by Performance Oriented - just completed
I just completed a set of 46mm Weber conversions.
Details:
- Price is $4250 plus shipping
- Conversion by Performance Oriented
- Cores are "Made in Italy" and are corrosion free
- Studs & gallery plugs removed for bead blasting
- Galleries and bodies pressure washed, ultrasonically cleaned and brushed
- All steel components refurbished and/or new and re-zinc plated
- New standard size, 8mm throttle shafts
- Six, sintered bronze throttle shaft bushings in each throttle housing
- Tune-able idle air correction screws
- IDTP "hatchet" accelerator cam lever arms
- Proven jetting based upon 38mm main venturis
- Bench set accelerator squirt outputs
- On-engine testing includes: idle fuel mixture adjustment; idle air flow balancing and float level adjusting
- More details and pictures available upon request
Attachment 513207Attachment 513209Attachment 513211
