I have a 911 2.4E with a 2.4T engine with S cams. The carburetor venturis are 28.5 mm, as original.
The S cams lift the valves 0.072" higher than the T cams. Does this imply that S cams provide correspondingly greater air flow? Or does the port size limit the flow anyway?
I am thinking about installing venturis with larger diameter.
Einar
