Robert, I sent you a PM.
Jon B.
Vista, CA
I am still interested in the SP registration and in the rest of the vehicles that will carry the M220. I've asked it before and I deduce the answer. NOT all vehicles with M220 carried SP marking correct? Can someone explain why in some vehicles yes and in others no? And... what other known vehicles have a handwritten SP? I'd be interested in seeing a picture...
Attachment 581439Attachment 581440
Attachment 581441
https://www.elferspot.com/en/car/por...-1973-1958421/
OT - would anyone have a spare 'SD" alu tag I could have ?
mine was lost somewhere between 1970 and today . . .
TIA
Dennis :)
Attachment 595006
How do you extract the percentage of LSD to make the COA? And how was it written down in the vehicle's construction sheet...? It may be a difficult question, but I want to put on the record here that "supposedly" the difference between "Normal" and "80%" LSD is written down somewhere.
I confess there is much interesting data about LSDs in this discussion. I was surprised about the 80% being standard configuration for the earlier 911s. One aspect of this 80 vs 40% situation I believe it actually quite simple. The early 911s didn't have a ton of torque so there wasn't much demand for a limited slip. Note the 80% information applies to "Sport Purpose" [competition] and suddenly the 80% makes perfect sense. If you missed it you may find it of interest that the factory commented to the effect that 40% worked best. It wasn't until the larger displacement 911s that a locking diff was more commonly used. A good portion of 930s came with them. I may have mentioned it before that an 80% was severe when used on the street, but that's a story unto itself. Keep having fun!
So, having a slip of 40% in 1972 would be a clue to know if it had a more powerful engine than the "normal" one... I understand that? Seen the manual published earlier by Gled. The question remains as to how to distinguish the LSD that the factory mounts between 40% and 80%. Can someone show the coa of their vehicle equipped with 220? Censored or private? The engines that I have shown in the previous COAs. Would they all be "strong..." engines? Would these all be racing cars?
Apart from this, all the 1972 vehicles (for example) made by the factory with which LSD were they assembled? Did it depend on the engine they put in the vehicle?
and fun yes! But if we all collaborate more, maybe we will come to understand some more things about the Porsche world...
All LSD’s in the early cars were 80% into the mid 70, then they were 40% thru 84 with multi plate diffs that could be adjusted. Then in 85 they became non adjustable 40%. If you didn’t like the locking value of an early diff you would adjust it, as there were 4 or 5 different adjustment settings. Don’t try to make a mountain out of a mole hill, it wasn’t that complicated. I did a 72 ST some years ago, it had 80% diff. The LSD option was not that common, mostly special order. The dealers I worked for never ordered them for cars they were flooring, thought they were dangerous.
