3 Attachment(s)
1970 911s - rebuild prep / parts / service | MFI bracket / breather / valve-train
1970 911s 9110310183 / eng. 6300551. Looking for recommendations on parts-source in prep for rebuild. Specifically the MFI specific parts.
Roughly in order of priority:
USED
- MFI bracket
- Crankcase breather for MFI
NEW
- valves and guides, springs, retainers, keepers, rocker arms, rocker arm shafts, rocker arm shaft Allen boot & nut, adjuster screws & nut.
- Dilvar or ARP - head studs and washers and barrel-nuts.
- trans 1, 2, 3 gears (possibly used) , dog teeth, sliders, magnesium case gasket set
- Tensioners, sliders, rails,
- oil return tubes
- etc
MISC (maybe donor motor)
- Cam gears & related nuts, washer, thrust plate, Woodruf keys, 6 bolts for thrust-plates (?)
REBUILD
- Distributor rebuild
- MFI pump inspection / rebuild
Thanks in advance!
Adam
Attachment 524411
Attachment 524415
Attachment 524416
